- Turn the system off and unplug it for a while, then plug it in again > No result.
- Check the screws in the back panel, if they are in the position corresponding to the position of use of the BS9000; in my case now flat on a table. > The screws are in the right position.
- Sensor cams. I have read that the two cams between the glass and the face panel might be dirty. I cleaned them with Isopropyl, and I also cleaned the glass and the face plate. > No result.
- Test Mode for CD mechanism test. I put the BS9000 in Test Mode with a Beo4 (Shift>9>0>2>5>8) and run #27 to test the CD mechanism. Here are the results:
- NO ML ERROR
- 1 IIC ERR104 = The 35IC2 motor processor
- 1 CD ERR 2 = Focus error, it has not been possible to find focus.
- NO SER ERROR
- 1 SLG ERR 31 = microprocessor 35IC2 cannot register pulses from 9PE1.
- NO PLT ERROR
- 1 APS ERROR 15 = it has taken more than 5 seconds to carry out auto positioning. The turntable motor driver might be defective.
- 1 PWR ERR 20 = Mains drop-out while the sledge was moving.
- What can I make of the result of run #27? (since there are several errors, I am not sure which one needs attention)
- Are there any other Test Mode runs I should do?
- Could it still be a dirty laser lens that I should clean?
